Electronics
The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
Re: Electronics
The toner pumps from the production machines makes for monster air pumps. Needs some PWM to control those beasts other wise the fish will get blow-waved.
No sense in caring around a car battery on the beach...
Will even pump fluids.WhateverComment
Re: Electronics
Anyone else out there playing with Arduino?
Took me 2 weeks straight to get a bootloader onto a blank chip.
Well at least I know how to use avrdude and all about FUSE bits and stuff.
Got a batch of Atmel ATmega 328P with non standard fuse bit settings.
That will keep u busy for a while.
Very frustrating if all the YouTube clips shows how easy it is and i just cant seem to get it to work.WhateverComment
EvenChu
Re: Electronics
Hi...i would like to share my stuff also. I made an automated tea infuser. It uses the two Canon primary wire cleaner motors and two DPST switches to drive Mita lens reduction gears. It drops the mechanism into two teacups then cycles once per second vertically 40mm. I wanted to be able to preset a timer in which the machine would retract from the cups, but never did figure that part out.Comment
Re: Electronics
Heh made a fully functional elevator model from scratch about 6 years back.
Making the PS for it was actually not really hard but making the parallel cables
and programming the integrated chips was a pain in the ass.
If i get the chance il send you a pic from a wah pedal i made from scratch for my guitar
using some parts from our beloved MFP's.
My father would love to join these kind of discussions
The wah pedal I would really like to see!Comment
Re: Electronics
Hi...i would like to share my stuff also. I made an automated tea infuser. It uses the two Canon primary wire cleaner motors and two DPST switches to drive Mita lens reduction gears. It drops the mechanism into two teacups then cycles once per second vertically 40mm. I wanted to be able to preset a timer in which the machine would retract from the cups, but never did figure that part out.If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Re: Electronics
B.C.
Has the Evenchu thread been cut & paste from another website?
Maybe the cut & paste thread could have come from a web crawler auto-bot?
I've had been getting what could be described as "ground-hog-day" type web pages from CTN.
Further more, I no longer get my regular email updates from CTN.
...Inauguration to the "AI cancel-culture" fraternity 1997...
•••••• •••[§]• |N | € | o | M | Δ | t | π | ¡ | x | •[§]••• ••••••Comment
Re: Electronics
B.C.
Maybe the cut & paste thread have come from a web crawler auto-bot?
http://www.copytechnet.com/forums/ra...tml#post517889
It doesn't look like a bot though. The paragraph was edited down. Can a bot do that? =^..^=If you'd like a serious answer to your request:
Re: Electronics
It was cut and pasted from here (I recognized my own words):
Yes there is text "concise driven" software on the internet. I haven't used concising software in years. There would be better AI driven software by now.
Example : Early versions of Microsoft Word did a context concise of the entire document before saving the document to the hard drive.
AI (Artificial Intelligent) driven software has been used for a very long time.
Without getting too bog down in code the implementation of AI, it has been done using the very early versions of Cobol and Prolog programming code. Basically Prolog/Cobol program code uses a lot of recursion. Recursion means the software code loops on itself to find pattern matches. When a pattern is found the result is output as a user response to the question they've typed in. The use of recursion algorithms code can give very convincing results that can lead the average user to believe it is a human response.
IMHO, Supercomputing using AI is going to become a problem in the future. Skynet senarios... hmmm maybe.
No power hungry group has the right to play at the living breathing god they believe they have become.Inauguration to the "AI cancel-culture" fraternity 1997...
Re: Electronics
News reporting agencies are using A.I. to produce news articles and report, for example
The Washington Post's robot reporter has published 850 articles in the past year - Digiday
Not sure how others feel about this but this scares the **** out of me. The opportunities for abuse , social and emotional manipulations are staggering.Comment
