Rubber rejuvenator? any suggestions
  • Waylon
    • Sep 2010
    • 26
    when cleaning feed rollers in copiers etc. we used to used alcohol, but that dries out rollers and shortens their natural life.
    for years we have used a product called HL Platten cleaner, by coopers, that we would get from Katun, but we cannot seem to find it any more.
    We are looking for product that will extend the natural life of rollers. any suggestions?
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: Rubber rejuvenator? any suggestions
    We have used WD-40 for the feed rollers that are rubber, not the neoprene ones though. Spray a cloth, not the rollers, and rub in. It works great on Sharp's resist rollers, removing paper dust and gives the hard rubber a soft touch. Just be sure to wipe down the rollers after cleaning.
      • 22914
      I've had good results from De-Solv-It Contractors Solvent. It's orange oil based, and works well on rubber (tires), neoprene (tires), plastic (covers), adhesive, but not so well on metal. Similar chemical combinations are used in floor wax stripper which works well also. =^..^=
      • Shadow
        PHD in Sh!t Disturbing
        • Sep 2011
        • 455
        I have used a product called " Simple Green "
        cut it with water at 60/40 and it works great on all rollers in the machine.
        $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          For actual rubber rollers I use Blow Off brand rubber rejuvenator. Works well although it does have an oder to it so be carefull in a customers office.
          Mystic Crystal Revelations
          • Iowatech
            Not a service manager
            • 3933
            Like ZOOTECH, I like using WD40. I've been using it for years to clean rubber rollers that are just dirty. And as I leave my tech tool case in the car, it is nice that WD40 doesn't freeze when temps get below 32F. Plus, it cleans off troublesome tape glue and a good deal of pen ink, too (although alcohol is usually best for most of that). While it is not adequate as a general purpose lubricant, when used carefully it has gotten me out of some nagging noise problems long enough that I was able to replace the affected parts, too.
            • JR2ALTA
              • Feb 2010
              • 2027
              Great product, yes will offend customers and eat plastic! so be careful with it.
              Max Professional - Quality Cleaners, Adhesives, and Lubricants
              • jose antonio
                • Dec 2012
                • 119
                For me it does not make sense to use "oil based" cleaners on rubber rollers.How do you get rid of all that
                oil sticking on the rollers
                In the past I always used Formula A from Xerox, now I am using Denatured alcohol 96% with acetone with good results.
                  • 2621
                  +1 for WD40
                    • 22914
                    The rubber is cleaned well. Any residual oil feeds off on the first piece of paper passed.
                    The only negative is that orange oil based cleaners cannot be used on plastics that are heated, like fuser covers. Extra solvent tends to collect in the screw valleys, then when heated attacks the plastic. The result is that your fuser cover falls off. =^..^=
                    • HenryT2
                      • 962
                      I have been working on Kyocera for the last five & 1/2 years .... and where I work, 99.5 % of the time we use WATER ( just plain water ) .
                      It works great on feed / sep / retard rollers, charge rollers , etc , and does not offend customers or eat plastic!
                      We also on occasion use 99% alcohol to get ink, etc, off covers when regular soap and a scrungy pad do not work .
                      "The Serenity Prayer" . . .
                      God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
                      • Dennison Tech
                        • Jul 2011
                        • 6
                        Fedron, old school - works great!
                        • ddude
                          General Troublemaker
                          • 473
                          YES!!?!?!!
                          But it offends in so many ways-
                          2000 mockingbirds = 2 kilomockingbirds
                          • ZOOTECH
                            • 3378
                            Originally posted by ddude
                            YES!!?!?!!
                            Yeah, it can clear a office space quicker than one of Shadows1 farts!
                            • nmfaxman
                              • 1703
                              Registration and transport rollers, citrus solvent from Image Supply Service. Won't melt plastic on contact.
                              Feed rollers, simple spit and rub to get the paper dust and toner off. Organic, spread by finger, no cost chemical, acid based and spread by oils from fingers. If they don't have a tread, replace them.
