RAW and LPR protocols
  • Blizzoo
    • Aug 2013
    • 608
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: RAW and LPR protocols
    Sometimes it goes the other way, where LPR works well and RAW does not. I have had that happen numerous times, just not recently.
    In in a few cases, both worked, but LPR was much faster.
    LPR is much older than RAW, and is normally the only protocol mainframe printing will support.
    RAW is now much more commonly supported than it was in recent years, perhaps the engineers are leading toward RAW more these days? I don't know, it's just a guess.
    Just good to know both are normally available, and that you may need to try both to see which one works better in each case.
    • ApeosMan
      • Nov 2009
      • 183
      LPR/LPD is older and has more overheads. LPD server's often require an accurate byte, meaning the computer the job is being sent from needs to spool the print job twice to get the correct byte count before transmitting to the printer. Also with LPR/LPD you usually have to wait for the entire job to spool on the printer before printing, depending on the printers configuration.
      Port 9100 or RAW sends the print data straight away to a printer in it's RAW format via a standard TCP/IP connection over port 9100, once the printer receives the data it's starts to print it, hence why it's quicker, though that being said I find port 9100 to be more unreliable in flaky network conditions due to less checks and balances.
      • peter42
        • Jan 2012
        • 110
        In LPR mode have always the queue name filled with "print" and "IMPORTANT" LPD-Bytecount marked.
        greetings peter
        • ApeosMan
          • Nov 2009
          • 183
          greetings peter
          Many modern LPD services on printers these days don't require the accurate byte count or a queue name, though I always enable the byte counting anyway just in case.
          If you need to use LPR when printing from Windows then I'd recommend creating a 'Standard TCP/IP' Port with LPR enabled over the traditional LPR Port Monitor for the reasons outlined below:
          Network Printer Ports - Microsoft Technet
