FTP in Mac OSX 10.13 High Sierra
  • Ceechtay
    • Sep 2011
    • 157
    Hi all,
    It appears that Apple has decided to remove the native FTP server in Mac OSX 10.13, which means we don't have the option of enabling it via Terminal.
    For our Sharp copiers, FTP was the best way to scan files to Macs.
    Anyone know of a free FTP solution to add to a Mac to re-enable FTP scan to folder?
    Thanks!
    • 37446
    Re: FTP in Mac OSX 10.13 High Sierra
    There's always Filezilla.
    Download FileZilla Client for Mac OS X
    • Ceechtay
      • Sep 2011
      • 157
      Thanks for the suggestion, but Fillezilla doesn't have an FTP server option for Mac. It has only the client software, which won't help us in this instance.
      I've been playing with Pure-FTPd, which is pure command line and am still working through it, when I have free time.
      Any other suggestions would be great.
      Thanks.
      • Codex
        • May 2008
        • 701
        Hello
        I use a canon tool, that creates a new user named "canon" and enables the ftp service and it works fine for me,tried last week on sierra
        Edit:i worked on Sierra 10.12!
        Memento Audere Semper
        • habik
          • 2013
          Have you tried SMB?
          Sent from my Mi A1 using Tapatalk
          Firmwares HERE
          • ZombieMccartney
            Originally posted by Codex
            Hello
            What tool did you use exactly? I have the same issue in my office, but I am not sure what steps you took to fix this issue.
            • Ceechtay
              • Sep 2011
              • 157
              As for SMB, the Sharp's don't play nice with Macs. I've never gotten it to work using SMB and I've seen a Sharp Tech Bulletin basically saying that changes to the Mac OSX some versions ago broke SMB from Sharp copiers to Macs.
              I suspect the Canon tool probably won't work in OSX10.13, if it enables the built-in FTP, since it is now gone.
              I'll get the Pure-FTPd working in near future, if I ever get a chance to commit an hour to it. Work has been crazy!!!
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                **COMPLETELY EXPERIMENTAL**
                I can get proftpd installed on macOS High Sierra 10.13 using the following terminal commands:
                Code:
                /usr/bin/ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
                Code:
                brew install proftpd
                Code:
                brew services start proftpd
                That is as far as I've managed to get though.
                I'm still trying to figure out how to configure proftpd and successfully login using a FTP client.
                • Ceechtay
                  • Sep 2011
                  • 157
                  I did get it to work using Pure-FTPd. I first tried using the Homebrew installer, but I was having a hard time figuring out where to do the configuration. So I uninstalled, and then did a straight, manual install.
                  After quite a few hurdles, I got it to work. I'll post barebones instructions when I get a chance. I plan to uninstall and redo from scratch to make sure I got everything right and will gladly share more detailed instructions then.
                  I was able to send to a folder on the Mac from the Sharp copier (I could also Filezilla into the Mac).
                  • Ceechtay
                    • Sep 2011
                    • 157
                    So here is my attempt at the quick and dirty of getting pure-ftpd to run on a Mac and authenticate using Mac accounts. I had originally tackled this using Homebrew to do the install, but I had difficulty knowing where to make the appropriate configuration changes. By configuring and compiling it manually, you can then configure it using its documentation.
                    So, first, you need to download the tarball (ZIP file) from pureftpd.org I used the 1.0.46 release (of course, they added the newest release today 1.0.47), but the steps should be pretty much the same for all releases. So, I downloaded: pure-ftpd-1.0.46.tar.gz
                    So, get the file and put it in whatever directory you want on the Mac. I left it in my Downloads directory.
                    Open up Terminal and go to the directory with the downloaded tarball. Extract it. Next, change into the extracted directory. You will then configure the installation. Last, you will compile and install. Here is the code (assuming it is in Downloads and is version 1.0.46).
                    Code:
                    cd ~/Downloads                            <- change to Downloads directory ->
                    tar xzf pure-ftpd-1.0.46.tar.gz        <- extract the tarball ->
                    cd pure-ftpd-1.0.46                       <- change into extracted folder ->
                    ./configure --with-everything --with-virtualchroot --without-humor        <-this configures the installer. You may also need the --with-pam switch ->
                    sudo make install-strip                  <- compile and install ->
                    At this point, it should be installed and ready to be run. The FTP server executable is in the /usr/local/sbin directory.
                    So, change to that directory and start the server.
                    So, run this:
                    Code:
                    cd /usr/local/sbin          <- change to the appropriate directory
                    sudo ./pure-ftpd &        <- start the server
                    If you test at this time using FileZilla, it should be able to connect anonymously, but not be able to upload. If you try to use the credentials of a user on the Mac, it should give an authentication error. At the least, you should be able to tell that the server is up and running.
                    You need to set up PAM authentication. To do this, you need to create a pure-ftpd file and put it in the /etc/pam.d/ directory.
                    Here is the sample file that should work. Remember that it is named: pure-ftpd
                    Code:
                    # pure-ftpd: auth account password session <- this is just a comment line
                    auth           required       pam_opendirectory.so
                    account      required       pam_permit.so
                    password    required       pam_deny.so
                    session      required       pam_permit.so
                    After placing that file in the /etc/pam.d/ directory, run the server start command again.
                    Code:
                    cd /usr/local/sbin
                    sudo ./pure-ftpd &
                    Test it again using FileZilla, and you should now be able to authenticate using a Mac user's credentials and then be able to browse that user's Home directory structure.
                    Once you get it to work, you need to ensure that it runs at start-up. I haven't tackled that little issue, but it shouldn't be too hard.
                    Hopefully, this is enough to get you in the right direction and if you do have any hiccups, you can figure it out. I had tried a lot of things before succeeding, so it's possible that I missed some step, although I did uninstall it and redo it using this and it worked.
                    Good Luck!
                    • George Baker
                      • Ceechtay
                        • Sep 2011
                        • 157
                        Thanks for the suggestion, but it appears that this app does not allow use of standard FTP ports (no ports allowed below 1024...standard FTP is at 20/21). It would work fine with an FTP client like FileZilla, but not with many copiers, which don't allow changing the port when scanning to FTP.
                        • Cipher
                          • May 2006
                          • 1309
                          Thanks for the guide Ceechtay, that helps.
                          It's about time they started adding support for scan-to-SFTP on MFDs.
                            • 37446
                            There are some newer Ricoh models where you can telnet in and change the port numbers.
                            • Cipher
                              • May 2006
                              • 1309
                              You can already change the FTP port number in the user mode settings and via the WIM on most models.
                              I was talking about support for scan to SFTP (SSH File Transfer Protocol).
                              SFTP is very firewall friendly. SFTP only needs port number 22 to be opened through the firewall.
                              This port is used for all SFTP communications, including the initial authentication, any commands issued, as well as any data transferred.
