RC Gate A connection problem
  • Mark
    • Mar 2019
    • 4
    We have an RC Gate A on our client with 100 RICOH machines located on their 3 different location (All connected w/ different VLAN).
    In location 1 (HO) & 2, all machines are connected to the RC Gate A.
    However, the RC Gate A can't get the details from the machines in location 3.
    Test we conduct on location 3:
    Pinging the IP addresses needed of Atremote= Successful
    Doing a manual test call (Reset, 0, 0, Clear) = Successful (machine will send an email to us using RC Gate)
    We tried to connect them as an Embedded = Failed
    Ports that are open: 443, 7443, 7444, 25
    Any suggestion?
  • qbert69
    • Mar 2013
    • 1152
    Re: RC Gate A connection problem
    Any suggestion?
    Does "RC Gate" use SNMP Protocol???[emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • zed255
      How'd ya manage that?
      • 1025
      If I remember correctly, the RC Gate uses SNMP to collect data 'internally', so port 161 would need to be open as well.
      Also, if you wanted to go embedded instead you need to remove the device from Centre Server if previously discovered / managed and perform the @Remote clear on the device (SP5-816-209, SP5-870-3, and either SP5-870-1 for 512bit or SP5-870-4 for 2048bit)
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3945
        Good point.
        I've run into a bunch of customers who block Port 161 by default.
        • Kimi
          • Feb 2018
          • 105
          Can you elaborate on cant get the details?
          • Mark
            • Mar 2019
            • 4
            Thanks for the suggestion...I'll try to confirm if they open the 161 too.
            As for the embedded scenario, we're not able to do it as they only want the RC Gate to get the details from the printer machine for security purposes.
            I'll be back if it will succeed
            The Atremote Center can't get the details of the printer using RC Gate like: Counter, Toner lvl & so on...
            specially the Last Report Date as it is the confirmation if the printer machine is connected
            • Mark
              • Mar 2019
              • 4
              Thank you guys...It's now working when we open the port 161
              • qbert69
                • Mar 2013
                • 1152
                It pays to think simple!!!....in other words, it's not always the copy machines fault!!!....if ya catch my drift!!![emoji6][emoji41]
