ricoh does not care about drivers to print on mac
  • medallo
    • Dec 2008
    • 21
    hi.
    why ricoh does not care about drivers to print on mac without postscript?
    How do you print those that have mac with ricoh with other paper sizes (not A4, not legal, not letter) other sizes?
    or I am bound to get sd card postscript
    • 29332
    Re: ricoh does not care about drivers to print on mac
    Only Canon supports PCL on Macs
    Why does't Ricoh add Postscript with all there Machines? Like Kyocera?
    Cost factor plus about 1 out every 100 installs I run into has a Mac
    • techandtrader
      • Jun 2016
      • 318
      Marketshare and last I knew Canon and HP are on top.
      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
      • copier tech
        • 8097
        Originally posted by medallo
        hi.
        The new Ricohs from MPCxx04ex have Postscript emulation as standard
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3945
          The key word here is “emulation”.
          In my experience, emulated PostScript normally fares poorly compared to genuine Adobe PostScript. PCL or Canon’s UFRII for Mac work fairly well, but not as well.
          It’s not a standard feature because a licensing fee goes to Adobe. There is no sense in including it as most users will never need it.
          Keep in mind, though, that many higher end Windows apps can take advantage of PostScript. And don’t forget that a lot of Linux flavors have a taste for it, too.
          Most Mac users have learned to expect the premium cost.
            • 36734
            MAC does have a built in Generic PCL Driver that does work with Ricoh. It does not allow setting options.
            • sandmanmac
              • 3968
              While I know this is true, I've often wondered myself how it is that even the cheapest 'box store' printers include P/S and when it comes to Ricoh, it's also a standard feature on the small MFP's and standalone printers
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3945
                I agree.
                Even my $150 Brother desktop printer has PostScript.
                Again, though, it's not Adobe PostScript. I think it's called "BrotherScript".
                Apparently, Ricoh feels that if you are purchasing a higher end printer, that you would want the real deal, and go for the Adobe version.
                Then again, who knows what kind of relationships printer manufacturers have with Adobe...that's not for us mere mortals to know.
                  • 36734
                  Originally posted by KenB
                  I agree.
                  Many current Ricoh do have a built in PostScript emulator. It does work on most things like PDF files. It gets a little wonky on most advance features.
                  • medallo
                    • Dec 2008
                    • 21
                    bad for ricoh.
                    Even minolta with the old bizhub c450 still prints well in mojave and with old driver.
                    A minolta if you care about customers.
                    • tonerhead
                      • Sep 2009
                      • 582
                      I agree.
                      I have heard it the other way, Ricoh is not the problem, Adobe is. The home based printers maybe do 1k/year. The higher end printers 1M+/yr. Greed from Adobe makes Ricoh pay $$$ for the postscript capability. They know they have a captive market, ie, buy it or go without. Mac users get used to the little throw-away printers that work and blame the manufacturers when they should be blaming Adobe. I deal Ricoh and Kyocera and both have emulations now that for the most part work fine. Maybe the better question might be why is Apple so stubborn about surrendering to PCL? There are probably licensing restrictions there for Macs also.
                      I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                      Especially when it comes to sex
                        • 36734
                        As I said previously, MAC does have a generic PCL printer. I have used it a number when the customer does not want to buy the PS3 option to allow the one MAC computer in their office that only prints occasionally to use their Ricoh.
                        • guitar9199
                          • Sep 2016
                          • 1099
                          There IS a workaround for PCL Printing on Macs, but we as a dealer don't support it.
                          This is ONE way to do it however.... Print to any PCL printer - Mac OS X Hints
                          ...Here's another. Gutenprint for Mac OS X
                          As always...installing unofficial print drivers on any operating system can open you up to all sorts of liability issues. If the customer's Mac "breaks"....it's going to be YOUR fault. Doesn't matter if it is or isn't....they're going to blame you.
                          If the customer doesn't spring for the PostScript, I let them know what the workaround is and I let THEIR IT guy handle it.
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3945
                            • guitar9199
                              • Sep 2016
                              • 1099
                              We had a "Dandy" one a few years back. Canon iR Advanced with a Fiery server on it, but it didn't support Cambria or Collibri fonts... so when the customer printed using them, it would substitute Wingdings!!
                              ...customer called asking why their machine was printing in "Heiroglyphics"!!
