Kyocera scan to smb on domain
  • n25an
    • Jul 2008
    • 1030
    I am trying trying to enter the right authentication style for a windows server to scan to smb to one of the shares.
    I know it has to be a folder on the root
    cann't be mapped...
    Just not sure of the style... Here are the various styles I have found for entering the user name in the address block for cs3501i
    domain\Username
    Username@Domain.com
    Username@Domain.local
    .Username
    Username@domain server ip address
    domain server ip address\Username
    and if it helps the server I am connecting to is windows server 2016
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • COPIERMAN
    • Jun 2009
    • 557
    Re: Kyocera scan to smb on domain
    YouTube show how to setup folder as for domain most i have seen show local
    • rthonpm
      • Aug 2007
      • 2849
      A shared folder doesn't have to be on the root of a drive, though you generally don't want them buried either. Generally the best format to use for your paths on any MFP are:
      User: domain\username
      Share: \\server\share
      or for a subfolder of a share (say a personal folder): \\server\share\folder
      Make sure the copier's DNS is not using an external DNS server like Google or OpenDNS. In a domain environment, only use internal DNS servers.
      If possible, see if the customer's IT can create a service account to access the shares instead of using a user's AD account. This also gives IT the ability to lock down the account so that it can't log into a computer directly and can only be used for authenticating to a resource.
        • 29306
        add the domain name
        under network settings on the copier
        rare that you would have to add domain name and user name
        what port?
        Whats the error message?
        • rthonpm
          • Aug 2007
          • 2849
          add the domain name
          what port?
          You would need a user name for an Active Directory network since open shares are very rare. If you're using open shares, make sure the customer is aware of it as well.
          Adding the domain name generally does very little other than append any queries that the machine has to do for DNS lookups.
          Sent from my BlackBerry using Tapatalk
            • 29306
            adding the domain name / windows see the machine as friend
              • 36689
              add the domain name
              what port?
              I don't know about Kyocera, but with Ricoh if the MFP is not a member of the domain, domain name properly set in network settings and primary DNS is the domain primary DNS, scan to folder is nearly impossible to set up.
              • mincopier
                • Dec 2015
                • 290
                We usually just create a local user that is used just for scanning. In this way when the domain user changes the password to their account the scanning will still work.
                • rthonpm
                  • Aug 2007
                  • 2849
                  I've done this in the past, but a service account is a better solution for many customers. A service account is an AD account that exists to allow a service or software to access network resources. Group policy can be set to allow the account to keep a static password and to also allow the account to access a network resource, like a share, but not be able to log into a computer.
                  • n25an
                    • Jul 2008
                    • 1030
                    Service account makes sense...
                    ++++note++++
                    I got this info just felt this was a good place to put it...
                    if the share is in the domain controller server then create the user account in the domain controller server
                    if the share is not in the domain controller then create a local user account to access the share...
                    and the customer network dept took over so I didn't get any resolutions...
                    ++++note++++
