Kyocera SMTP error - SSL/TLS - stopped working
  • stroltz
    • Jun 2020
    • 4
    We have multiple ECOSYS M6530cdn printers - send email has stopped working using SSL/TLS ( Connection Error (0x4803)
    We have a single newer ECOSYS M6230cidn - and the send email still works just fine with SSL/TLS. Is on the same network as a broken one.
    I can't see any difference in the relevant settings between the new and old machines.
    The mail server is a cpanel hosted webserver. version 88.0.10 Nothing much special about it as far as I can tell.
    The old M6530cdn will work if I switch to no SSL but we want to use SSL.
    I have tried generating a new security certificate.
    Switching off SSL3.0/TLS1.0 and TLS1.1
    Using the IP of the sever instead of the name.
    I can't find any firmware files to download for the M6530cdn
    Does anyone please have any ideas?
    my guess is that an update on the server has broken the SSL/TLS for the older version used by the older machines. I hope there is a way to get it to work?
  • tsbservice
    Field tech
    • 7904
    Re: Kyocera SMTP error - SSL/TLS - stopped working
    I think you will need newer firmware on troubled machines.
    • stroltz
      • Jun 2020
      • 4
      Thanks.
      That is what I suspected.
      I have asked Kyocera. There does not seem to be a way for me to access the firmware download.
      Here are the numbers of the firmware the M6530cdn has installed, that no longer work.
      System : 2NW_2000.003.204
      Engine : 2PC_1000.001.107
      FAX : 2NM_5100.006.009
      • stroltz
        • Jun 2020
        • 4
        I have been told there is a firmware update available;
        M6530cdn_7.113_4.005
        but of course it costs a fee to have someone come out; and there is no guarantee that a new firmware will fix the problem.
        I wish I could download the file somehow.....
        stroltz@hotmail.com
        • davel
          • Oct 2011
          • 1074
          You have updated I/S on your server, pay for Kyocera to fix it then send the bill to Microsoft for breaking your machines. LOL.
          • stroltz
            • Jun 2020
            • 4
            In case anyone has the same problem.
            The new firmware 7.4.0030 fixed the issue.
            I got it from Firmware Update - Printer & Copier Firmware - so had to pay - but a lot cheaper than a service call from Kyocera.
            • copier tech
              • 8096
              Happy to help, glad this resolved your issue.
              • finlay31
                • Jan 2021
                • 8
                When you use an old browser or operating system you will encounter err_ssl_version_or_cipher_mismatch error . You might even face a variant of this error message .
                It happens mainly because the browser does not trust the SSL certificate and there are many ways that you can check to fix the error .
