MP C407 Over 50 pages sending jumbled files
  • digicor
    • 1134
    I have a mp c407 sending jumbled files after 50 pages, under 50 pages its fine, a pdf, no problem,
    In batch it does the same thing , can i get any suggestions? My web service provider has no limits and if it did it would bounce back
    Thank you for any ideas
    example
    :yhyhyhyhyhyhyhyhyhyhyhyhzjlDnHOOccococ45Q5xwSQQTCYTCYTCYTCwgmCSI6I+R8joj
    5HRHyPpaTOOYcEkEEwmE0EE00EE01tNbWGUcqaEyCJFcVxQZQQrERCZQwEggtUgkkkkEkggt
    JJEfiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiwQiIiIiIiIiIiIi
    Ii0LK8JhMJppLa2kndBBBNXpBBIJJIIJpIILSQSCCC0gkEF6QQW0kEFpJJJJBBaQQWkEFukR
    2kCC0ggmrSSCQSBBbVVtJBJJJJJJBIJBJBJ1QQSCQSppBJJBAqPJBJJIJAgVBJIJBIJJKggT
    tIIErdhIJBBWoSCSQQSQQSSQQKkgkEFd3DCQSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSC
    SQThpKt20ggr1SCQSCSSQQW0gkEkGgwkggmgRQ4SBIJJhaQQTQQTCaCCYJIIJoECSCCYWkCB
    JEdEfI8kXRHwgmcc45xzjnHKHKHKHKHKHKHOOcc45xzjlDnHOOccw5xzjkxyxyMcmOYcw5hz
    DnHOOccmOcc45CjkUc45hwSRHyPEeI+R8jxHyPAgsjyRHwSI7I8R9IjxHyPkcyOaRHkiPkcH
    CQQTOOYcEkCC2ggmggmtpJJpJ5LowidYiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiI
    iIiIiIiIiIiIiIiIiIiIiIiIiIiIiIkdAgQiIiIsIRFIRSYTCFlUSSSTCFJJJghYIdJpJLSS
    CCYWkEmktpJppppJJJJJJJJJJJJJJJJJJIJJEdgkkEgkEggkkkEkgkkEFekklhpBIJEcQJJB
    JJU1QNJJVvW7SCCSSQaSSSSSCCtJBJBJ1SCQQWkkkkkkkEgkEgkEkgkEFqEggtIq7CRXWCQI
    K0gQVpBBapFYEgkUgr7tQSSCQJAkEgkCQSBBXYJJBIEFB2kEkgSCQSKwq+DSCRWgSQQSBIqn
    pIJJBBNBBXYatJIEEMRyUojxOjkR8jxdEfI6I6J0R88i6I6I6KEIiIiIiIiIiIiIiIiIiIiI
    iIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiLTTTCaDSBMJoIJpra2ggt
    IJBBX3tBBW0kkR69IjwSCQIK9JIJBLaCSRHd3ZHFkY7vSBBbQIK1SCQJBIJBIJAkkEgkR6++
    1VSPSY6I7SCRHBwkggkCRHESSSQSSDSQSCI7CCSSQRHpLowhJCNEwRHRHrhBMK0tJrRH4tQg
    ZtH0XFNkeFL57I4Q+jCNaPowiORgzxnVGEfR9GEfRhEdF0cR9EUROjImibrGIiIiIiIiIiIi
    IiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiIiLCERFIRaEcSfFEVSEU
    EIiIiKCERFFcUiTo0xcRxM0yjxlQ0Vb2fPpWEiOtIEDBAzgpszyPI+j6PI2RjPonRdGaM8uy
    OjfkoM3EfI8XR5G8joj5xF0Q0IiJ5RwScT3kdGecWfRhJZhZhCYQZUFURHRxHkJhaRHRxaQZ
    UQyqwv2VCFlWVmVxUFcVZVR7bKxJZOgysSQsr0MMRJ0cJFW2kEgRHXoIIWR8IMjoIjmVhCDk
    RuVnZ1UQZXBCa0OygNfjiJ5Mo9ojryQsWsf8h+R8RZXfZVxHFIoQhlEH49CuY4mEkR0kbQm0
    S6SlF4ZXoccRFlUK4rkR0Iia8jCM0cCFxTbKCOkR8j5dGxS6PovEdEePop0fR5EdnEZojxHz
    5kdm4kIoRyM0R0VJHYhGRapFUIkdZ9JCfR7FghHPZhaR5Y4/maSLrMLHERc2j6SxHSOrNoj5
    9HlnkKQQQm0gkEfWJtJE6x2CZWFE4JEdCkyu55CToREczR5FuqZmkEXyETOTKs+pXGqK0PmE
    kLK4qD8V1lWeO0giOpVlDhIEY0jmKBGJJErKw8yrK4pAM4jyMDODOCl0fRHiOQSI8fM8ZxH0
    YIzRwIXRwziPoZL5iyQjixxMJlcRzKII5lBJHQIEkyhyhwhyOQIJlQV0Rx/I7ZxyvNWVAJlR
    /MI8mCFFWVEfxMY5dMq0YQl1iwQiIQQhAhFlQUNzixERMITyNEewghxEJCGVUVxXBE6PJITR
    • 7975
    Re: MP C407 Over 50 pages sending jumbled files
    example
    This is a common issue & usually a quick fix.
    Update the firmware, driver & ensure the driver port is IP address of the printer NOT wsd.
    If this is a gmail scanning issue check fil size is set to MAX & update the firmware.
    • Brianneoe
      • May 2015
      • 317
      There are 2 settings you want to change. Max file size (default=2084) to at least 20000kb. On the same page, turn off divide and send. Divide and send will take the file you are sending and once it goes over the Max file size it will send the remaining file in a different file format that nobody knows what program to use to open it with.
      • digicor
        • 1134
        Max file size is OFF and divide and send is OFF
        i always default these to off during set up and delivery
