Ricoh PCL6 V4 Driver for Universal Print what are your thoughts?
Hi what are your thoughts on this printer driver PCL6 V4 Driver for Universal Print for Ricoh?
i tried it before one one printer and it prints out funny texts.
Re: Ricoh PCL6 V4 Driver for Universal Print what are your thoughts?
Unless you have a real use case for v4 drivers, stick with the traditional type 3 driver.
Type 4 drivers only support Windows, if you use them on a server they do not download to the client like a Type 3 driver would. If the client has the driver installed, it will use it; otherwise it uses a generic point and print driver, which can give you some odd output depending on the file type. Any shared print queue using a Type 4 driver cannot be used by another OS so any Macs, Linux, or mobile devices using the queue won't be able to access the printer.
In theory, Type 4 drivers are a great idea: processor independent, able to be directly embedded into an application, and able to work outside of the the general print spooler. In reality, they're more trouble than worth.
Sent from my BlackBerry using Tapatalk
Reason: Completed my thought.
