Hi All,
I have a Ricoh Mp301 upgraded to newest firmware. It supports TLS 1.2. I have set it up to scan to email via office 365.
Anyone with more experience can explain why and is there a way to force it to encrypt the password ?
Also, the settings that I see on the web administration page versus the settings on the printer screen are different.
For example:
Any idea how to update these remotely, versus going to different sites ?
Thank you.
- If i set up SMTP Auth. Encryption to Auto it works.
- If i change it to Active it doesn't work.
For example:
- On the web page I'm missing Use secure connection (ssl) for smtp (however, on the printer itself , i see this option).
- On the web page i had set up the smtp port to 587, but on the printer itself it was different I believe it was set to 465 and had to update it directly.
- Also on the web page missing is the option to auto specify sender for scanning to email. It is available on the printer itself.
Thank you.
