We have a couple of CS-420i's at one account that we are experiencing printing issues with. The print job get stuck in the machines 'Status\Cancel Job' queue with a status of 'In Process'. If you cancel the job, all the jobs behind it come out just fine. Here's the breakdown of what I found. I witnessed one docx file get stuck. I printed the same file, same settings, same printer same everything and it went through without a hiccup. Did the same thing about 15 times with no problems. My thoughts are if it were a driver, machine, or document issue it would be a consistent problem and not so random.
I also want to mention the job completely leaves the queue on the print server and the machine has the latest firmware and the driver is the most current. Any ideas or thoughts on why the job would hang 'In Process' on the machines?
