Installing printer driver on a mac
  • Nikstar
    • Apr 2025
    Hi,
    I have a Mac and want to connect it to the printer at my work. It is a Toshiba E-Studio 4520c and has wireless network capabilities.
    I have installed the drive on my computer but cant seem to get it to show up in the printer list when I click on the 'add printer' option.
    What am i doing wrong??? Any help would be greatly appreciated!
  • Daren
    • Nov 2011
    • 14
    Re: Installing printer driver on a mac
    Hi,
    Did you download the PPD from Toshiba web site or do you have the blue client utilities CD that comes with the machine?
    Daren
    • Nikstar
      I downloaded it from the Toshiba website.
      Not sure if we are allowed to post links but this is the link for the page that I got the PPD download from:Toshiba - Photocopiers, printers and fax
      I downloaded the 0S X 10.6 version.
      • Daren
        • Nov 2011
        • 14
        That looks OK
        Then run the PPD file. That installs the drivers to where they need to be. System Prefs, Print and Fax, Click the +, it should find the copier normally with bonjour, then select the driver at the bottom.
        If it's not appearing then check that bonjour is enabled on the copier.
        • Nikstar
          Thank you! Will try that and see how it goes.
