SMB to Mac
  • richs
    • Nov 2008
    • 252
    SMB to Mac
    Most of my installs are OKI MFPs.When I try to scan to a shared folder on a mac I always have to use the ip address .I can never get the computer name to work.This would be OK except most are using DHCP.Is anyone else have a similar issue.Thanks!
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: SMB to Mac
    If you are having problems with network name resolutions, double check that you have entered all your network details correctly. Specifically, the DNS, gateway, etc, addresses. If all else fails you can (or get the customers IT department) to set up IP reservations for the devices against their MAC addresses.
    • rthonpm
      • Aug 2007
      • 2849
      Re: SMB to Mac
      In the network settings of the Macs, you can add a Host name for each interface, sometimes this doesn't give you the same name as the host name set in System Preferences so it can be helpful to double check. Also make sure that the Macs are set to allow file sharing through their firewall. If they're running 10.7+ then you may need to wait for firmware updates as Apple has decided to use their own proprietary version of SMB which not all MFPs are able to communicate with properly.
      Apple just likes being difficult any way they possibly can.
      • TheOwl
        • Nov 2008
        • 1733
        Re: SMB to Mac
        As what rthonpm said, the device name can differ to the name given to it by the base Linux system.
        Going into System Preferences > Sharing should give you the host name for the share. The other thing that you can try is put ".local" at the end of the host name.
        • RollingROARANDA
          • Nov 2012
          • 72
          Re: SMB to Mac
          I have noticed that through all the MFPs I've setup with Macs, that the MFP wont resolve the Mac's hostname, on even the most stable of networks, (small office, good equipment, proper cabling) properly configured network settings on the MFP seem to count for nothing..
          Setup DHCP reservation by first obtaining the Mac's layer 2 address (MAC address) by going System Preferences>Network> Airport or Built-in Ethernet (depending on the access method here) click Advanced..
          Airport ID= wifi card MAC address
          Ethernet ID= NIC MAC address
          Next part depends if you have the router password or not, and the capability of that device.. typically, you'll just bind an IP in the reservation list to a MAC address..
          My company, we sell SOHO routers and network equipment as an available option to the customer...
          If they're not content with just scan to email, I let them know as best I can if there's this hitch with scan to folder..
