Copystar/Kyocera KX Driver Bug
    • 22917
    This is the same driver used on all Copystar/Kyocera as far as I know.
    I found a bug the other day in driver version 4.2.1409 on a CS-6030 with DF650 & PH5. When selecting legal paper size and 2 hole punch, the resulting print is not punched. If letter R size paper is selected it does punch.
    After wasting an hour manipulating settings, I loaded the new KX driver version 4.4.0403 18 April 2008. Additionally, when conflicting settings are attempted (i.e. output tray B + stapling) a cool little pop up message explains why you can't do that.
    I hope this helps someone not have to waste that hour.
