ricoh print via email
  • slot
    • Jul 2008
    • 341
    We have a new install to do soon and the customer has asked that the copier can be sent an email from the workers from home then printed off when they get to work for example a word doc. they have provided email address for the copiers im sure you can do this but not sure how they are all the new 3 type copiers and some mpc305/301 so do they need HDD has anyone out their set this up many thank for your input.
  • rthonpm
    • Aug 2007
    • 2849
    Re: ricoh print via email
    There is a feature called Mail to Print that works on some Ricoh models. You need to have at least PostScript for it to work. It's not offered on all models, so you'll have to check: it's usually buried in the fax section.
    • slot
      • Jul 2008
      • 341
      many thanks I will look into it
        • 36667
        Most of the Ricoh machines that I know do allow you to receive and print email, but not selectively. When an email is received it is printed at that time, regardless of who or where it is from. Check into Ricoh's Cloud Print solutions. If the model supports one of them, employees can send print jobs from anywhere and retrieve them when they are the office. Some of the solutions do require a HDD on the machine to store the jobs, but others store the job on a cloud server and require an APP on the machine to retrieve them. Ricoh Learning Institute has a number of online training courses on them.
        • rthonpm
          • Aug 2007
          • 2849
          To delay printing of Mail to Print, you can always change the email reception setting to on demand as opposed to automatic. That will make the user have to have the machine pull the emails from the server.
          --sent from my BlackBerry using the Android app
          • ruben
            The New Guy
            • Oct 2012
            • 1204
            If they have a server or a Pro version of Windows, then setup a VPN.
            See: How to Set Up VPN in Windows 7 | PCWorld
