Hopefully, this is the correct forum for this issue. Anyway, I'm running a Windows Server 2012R2 print server, fully updated. I've got a mix of MFC's, mostly Savin MP5002's, and MPC4503's, but a few oddballs, as well. All of the copiers are on the latest firmware update and installed using the latest manufacturer model-specific PCL6 drivers (no universal print drivers). Most of our users print PDF's, almost exclusively. Occasional, a user will attempt to print a PDF, but it will show up in the queue as 'Offline Printing' and the copier lists as 'Offline' in Windows Print Management, on the print server. Other users are able to submit print jobs to that copier, but they just stack in the queue. I normally have to delete the job, in the queue, and restart the print spooler service. This corrects the issue, and the queue clears out. The user is able to successfully print the PDF that originally was listed as 'Offline - Printing', once I've bounced the print spooler service. It happens to several of the copiers, and it's not model specific. I have a Muratec MFX-35x0 that gives me trouble, too. I don't see any relevant errors in the event viewer and our copier service provider has no clue. Any idea what keeps causing this to happen?
Thanks,
Kris
Thanks,
Kris
