canon ir-8070 error e000012-0000
  • tariq65
    • Jun 2010
    • 84
    [Error Code] canon ir-8070 error e000012-0000
    hello to all my canon ir-8070 showing error e000012-0000 how can solve this problem help me thank you.
  • chronica
    • Sep 2015
    • 6
    Re: canon ir-8070 error e000012-0000
    E012 there is a drum motor error
    • hsrmms
      • Dec 2014
      • 69
      Check the drum and cleaning blade, maybe you need replace anew drum and if the drum is ok check and replace drum motor.
      • teckat
        • 16084
        if the waste toner drive assembly or cleaning assembly is binding a E012 could occur.
        • tinnyjay
          • Oct 2009
          • 654
          Check the gear that has contact with drum's motor.
          "Who loves the roses,must also bear thumbs"
