Dear Sir,
How to Access the Internal Storage from Hard Disk of the Canon IR Machine ?
I have a Requirement that I should be able to access the Internal Storage and then save the Files on Computer.
Can I access the Internal Storage as \\IpAddress of Canon IR Machine ?
Say the IP Address of Canon IR Printer 10.10.10.100 then can I use \\10.10.10.100 to access the Internal Storage and then do copy paste the Scanned Document ?
If the above is possible then what is the Which canon IR Machine Supports this ?
If the above is NOT possible then what is the easy way to copy paste or save the scanned documents from the Internal Storage ?
Thanking You.
Thanking You.
