I have a customer with a DR-G1100 that won't feed. The elevator lifts and the feed motor turns on but the pickup motor never fires. According to the service manual the machine should have come with a disc that has the service software on it. They have the setup disc but that's it. Does any have or know where I can get this. I'd really like to use it to determine if the motor operates in service mode before making the assumption that it's a bad board. I have ohmed out the pickup feed motor and the one that sits next to it that is the same motor, they both have about the same reading when you spin the motors by hand.
Any help or direction would be appreciated.
