Canon DR-G1100 Scanner
  • iscott
    • Mar 2010
    • 344
    Anyone cross trained on this machine? It is jamming when feeding variable thickness paper. The machine is a few years old and has never done this before.
    We have thought about replacing the sonic sensor board, but the felling is that's not going to help. I appears to be a bad sensor of some kind or a setting change that someone has done and won't admit to. Paper feed fine (no tire slipage or anything), but jams at exit (Paper does not completely exit machine). At the user panel there is a setting for auto paper thickness (I think). Low Normal High are the options these have no effect. Any help is appreciated.
  • ccolzie
    • 2
    Re: Canon DR-G1100 Scanner
    What jam or error codes are you getting
