Ir 3245 sending email very slow
  • browny
    • 81
    [Misc] Ir 3245 sending email very slow
    HELLO ALL
    We have 10 CANON IR 3245 ,when CUSTOMERS scan documents ( even 1 page ) : it take too long to complete sending ( 3 to 5 minutes ) ... do you have any idea to make them faster sending . THANK YOU .
  • roho
    • Mar 2009
    • 844
    Re: Ir 3245 sending email very slow
    Try compact pdf for format, had that issue many times before.
    • browny
      • 81
      Thanks for reply. But I'm talking about SCANING DOCUMENTS FROM THE MACHINE IR 3245 TO SENT...
      • copier tech
        • 8095
        Yes try setting compact PDF.
        If scan to folder is fast then it can only really be their network or SMTP server etc.
        As a test use a gmail account to send the same file.
        • luis1984bol
          • Nov 2011
          • 143
          Try sending the documents changing the sending configurations like resolution (150 dpi).
          1.- Print a configuration network report.
          2.- Perform MMI in SERVICE MODE.
          3.- Reset the printer.
          4.- Configure the network settings again.
          5.- Try sending a document.
