Canon IR 3235 no network options in settings.
  • LTTP
    • Oct 2016
    • 83
  • teckat
    • 16084
    Re: Canon IR 3235 no network options in settings.
    If you are unable to see any Network Settings on the imageRUNNER then the Ethernet Board may not be securely seated. Un-seat and re-seat the network board.
    Also the imageRUNNER may be switched in the imagePASS mode and needs to be switched off that mode to show the Network Settings option.
    To switch off the imagePASS mode follow the instructions below:
    Enter Service mode (Additional Functions > 2 & 8 > Additional Functions).
    Select Copier > Option > INT-FACE > IMG-CONT.
    Change the setting to "0" and press OK.
    Power Cycle the imageRUNNER.
    The Network Settings option should now be available within the System Settings menu of Additional Functions. If it is not available after setting the IMG-CONT setting to "0" even if it was set to "0" already then perform a "CLEAR-MMI".
    To perform a "CLEAR-MMI":
    Select Copier > Function > CLEAR > CLEAR-MMI.
    Highlight "CLEAR-MMI" and press OK.
    Note: The problem on some copier models could be caused by the Ethernet Board not securely seated, re-seat the board.
    • campy
      • May 2012
      • 315
      Check to see if the network settings are on (top option where you put the ip address in). If off the settings are grayed out.
