Canon IR Adv. C5030 / Ser# GNG35555 / Total Prints 240,415
Copier located in Prescott, AZ Mountains. Hard to get to. Need help before I go.
This code returns or changes between 000012 -0206 and 0204.
-Suggests drum rotation issue among other things (ITB, Drum Driver PCB, ITB Blade)
Having worked in the industry since '86, I know that great techs sometimes find something that consistently fails across the board on a particular unit.
My Question.
Do any of you guys have inside info on this code that comes from experience. Maybe a "GO HERE FIRST" type tip. I am toying with just replacing the magenta drum first.
This is a pretty clean unit so I don't think it's a sensor, however, I am aware that there is a Tech Pub (N08-051) on this unit as regards addressing an E012-0x04 code.
This suggests replacing the Drum Encoder PCB Assy. Would this cause my error codes as well.
I sold it used with no history and it has been very reliable up to this point.
Thanx Guys!!!
(I still miss Smarka)
Pete from Prescott
My Question.
Thanx Guys!!!
Pete from Prescott
