hello
i have Canon i-sensys MF623cn ,code error E015-0001
help me please
not sure if MF623cn is same as below model ????
----------------------------------------------------------------------- on the MF634dw
E015-0001--- Cassette 1 lift-up error
Detection Description After lift-up of the Lifting Plate of the cassette of the host machine started, ON status of the Lifter
Sensor of the cassette of the host machine was not detected within the specified period of time.
Remedy 1. While the cassette of the host machine is removed, turn ON the power and insert the cassette,
then check the operation sound of the motor.
When there is operation sound of the motor, check if the Lifting Plate has been lifted up.
When the Lifting Plate has been lifted up:
1-1. Check that the Lifter Sensor of the cassette of the host machine is properly installed.
1-2. Check the harness/connector between the Engine Controller PCB and the Lifter Sensor.
1-3. Replace the Lifter Sensor.1-4. Replace the Engine Controller PCB.
When the Lifting Plate has not been lifted up:
2-1. Check the condition of the gear at the host machine side (missing teeth, swing).
2-2. Check the harness/connector between the Engine Controller PCB and the Lifter Solenoid of
the cassette of the host machine.
2-3. Replace the Lifter Solenoid.
2-4. Replace the Pickup Motor of the cassette of the host machine.
2-5. Replace the Driver PCB.
2-6. Replace the Engine Controller PCB.
When there is no operation sound of the motor, check the followings:
3-1. Check the harness/connector between the Engine Controller PCB and the Pickup Motor of
3-2. Check the condition of the gear at the host machine side (missing teeth, swing).
3-3. Check the Pickup Motor.
3-4. Replace the Driver PCB.
3-5. Replace the Engine Controller PCB.
thank's
when Remove the thermal fuse cable from the power supply "SECONDARY PRIMARY" (FM0-3910(200v)) and run machine display error E000-0000, then off machine and reconnect the cable , run machine It works well for an hour after it returns off the error E015-0001
Where is the problem exactly ?
thank's
u can't remove thermal connection cable and expect printer to not error out in a E000-000 code
are u a tech ?? if so u would know that
did u check this
E015 - 0001 = Error in Developing Disengagement Motor
Description = Change in signal status of the Developing Home Position Sensor could not be detected althougha specified period of time has passed after rotating the Main Motor for engagement/disengagement operation of the Developing Cylinder. Remedy =
1. Check the connectors connecting the Developing Home Position Sensor, Main Motorand the DC Controller PCB.
2. Replace the Developing Home Position Sensor.
3. Replace the Main Motor.
4. Replace the DC Controller PCB
so the code E015-001 is disappear, but the display code error E000-0000 after moments help me please
[Related error code] : E000-0000 E000 0000= Error in temperature rising of Fixing Assembly Temperature of the Fixing Assembly did not reach a certain temperature within the specified
period of time. 1. Check the connector connection between the Fixing Assembly and the DC Controller
PCB.
2. Replace the Fixing Assembly.
3. Replace the DC Controller PCB.
\I have almost the same error code, E015 - 0000, with Canon MF 735cx. Do you have any idea where to search the problem?
Thank you in advance
PCB.
