Scan-to-folder with SMB 1.0 / CIFS disabled?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    One of our customers with an iR C5255i has disabled SMB v1 on their server due to the WannaCry malware attacks and their scan to folder shares has stopped working.
    I've re-created this in our workshop on an iR C5235i connected to a Windows 10 laptop via a crossover cable (firewall disabled).
    I can browse my laptop shares on the Canon and scan into them just fine with SMB 1.0 / CIFS enabled, but after disabling SMB 1.0 / CIFS all I get is a ' no response ' error message.
    Both the customers machine and our workshop machine have been updated to the same and latest firmware version on SIMS (v46.01.02).
    Any one come across a solution for this?
    (Apart from leaving SMB v1 enabled of coarse).
    Cheers.
  • teckat
    • 16084
    Re: Scan-to-folder with SMB 1.0 / CIFS disabled?
    Windows 10 tip: Stop using the horribly insecure SMBv1 protocol | ZDNet
    WannaCry Ransomware has become very active in May 2017. It looks to be targeting servers using the SMBv1 protocol.
    SMBv1 is an outdated protocol that should be disabled on all networks.
    One of the big lessons from this Ransomware outbreak is that it is vital that you have monitoring in place on your network.
    You need to be able to quickly identify suspicious activity.
    There are six things to watch out for when it comes to detecting WannaCry Ransomware:
    1. Check for SMBv1 use
    2. Check your web and DNS traffic for any attempts to connect to these domains:
      • iuqerfsodp9ifjaposdfjhgosurijfaewrwergwea.com.
      • ifferfsodp9ifjaposdfjhgosurijfaewrwergwea.com
      • ayylmaotjhsstasdfasdfasdfasdfasdfasdfasdf.com
      • iuqssfsodp9ifjaposdfjhgosurijfaewrwergwea.com
      • iuqerfsodp9ifjaposdfjhgosurijfaewrwergweb.com
    3. Check for an increase in the rate of file renames on your network
    4. Look out for any outbound traffic on TCP 445. This really should be blocked
    5. Check for any instances of the file @Please_Read_Me@.txt on your file shares
    6. Check for any instances of files with these extensions
      • .wnry
      • .wcry
      • .wncry
      • .wncryt
    SMBv1 is deprecated
    • Cipher
      • May 2006
      • 1309
      According to Canon support.
      Gen 2 models only support SMB v1.
      Later models (Gen 2.5) support SMB v2.
      And Gen 3 models support SMB v2 and will add support for SMB v3 when updated.
      • teckat
        • 16084
        • Cipher
          • May 2006
          • 1309
          Your answer has nothing to do with my original question.
          Of coarse v1 should not be used.
          • 20 year tech
            • May 2014
            • 580
            I believe you can use FTP
            • yazj
              • Aug 2011
              • 29
              Hi Guys,
              Anything we can do with this. we advice my customer to user the following FTP/Email/WebDAV
              but my customer is insisting the Scan to Folder, but this is the limitation of Canon Gen2 Devices which will not support SMB2.
              do we have any device adapter or any device that can do the conversion of protocol just attached to this devices and we can do the scanning to SMB v2?
              any advice will be highly appreciated.
              thank
              Jason
