Installation canon ir 2520 windows 7,8 and 10
  • jubest
    • Apr 2025
    How to make installation canon ir 2520 windows 7,8 and 10
  • ldharnden
    • Apr 2011
    • 47
    Re: Installation canon ir 2520 windows 7,8 and 10
    Please clarify. Are you trying to install the drivers? Connect to your network? Need more detail as to the problem.
    • jubest
      yes i have 3 computer with deferent windows all are in network
      what can i do
      • ldharnden
        • Apr 2011
        • 47
        what can i do
        Goto to canon's website and download the driver for Windows. To make it easy start with installing the UFR driver, the same installed will work for all three versions of Windows. That should work for you.
        • Ibrahimba
          • Jun 2016
          • 10
          Hello!
          First, there must be some LAN network where the computers and Canon devices will work. Set IP address to DHCP, let computers see each other. On the Canon device, set the IP address of the DHCP, returne to the copy, and then install the driver from Canon on each computer. Choose a typical installation and that's it ....
