Canon Imagerunner 2020 - Nothing showing up on Control Panel
  • screwdriver08
    • Jul 2010
    • 160
    [Dead] Canon Imagerunner 2020 - Nothing showing up on Control Panel
    Copier was working all right. After turning it off and then on the next day there was nothing showing up on the Control Panel, the Copier has power. The Power light on the control panel does turn on when plugged and seems like it is the only one that lights up on the control panel. There is nothing showing at all on the display, so I cant even tell what error it is. I checked the Flat Cable connection from the Control Panel to the Board on the side and seems like it is ok.
    If you have any advice or help please do share.
    Thank You
  • JPiek
    • Oct 2014
    • 435
    Re: Canon Imagerunner 2020 - Nothing showing up on Control Panel
    Apart from a blank display, does it boot up at all ? Does in initialise ?
    I mean, is it just a blank display or is it dead apart form the powerlight ?
    Johan
    • copyman
      Owner / Technician
      • Sep 2005
      • 4511
      reload system software
      • screwdriver08
        • Jul 2010
        • 160
        It does turn on, but it does not initialize, making sounds that the parts are running and warming up.
        all it does is the light turns on when I turn the power on...that is about it
        • JPiek
          • Oct 2014
          • 435
          Can you boot into download mode (press 2+8 and power on) ?
          Johan
          • screwdriver08
            • Jul 2010
            • 160
            JPiek, Thank You, but I tried pressing down the numbers 2 AND 8 on the Control Panel and nothing happened. It just turned on like before, it would just turn on and makes the sound like it is about to initialize and then stops. But only the light on POWER on the Control Panel is on.
            Do I have to connect it to a Computer to do what you instructed?
            • screwdriver08
              • Jul 2010
              • 160
              Thanks for the Reply Copyman, can you please tell me how to reload the system software?
              • JPiek
                • Oct 2014
                • 435
                No, just press 2and 8 and hold them while powering on.. Keep them pressed until booting in finished (if it will boot)...
                Johan
                • screwdriver08
                  • Jul 2010
                  • 160
                  Thanks JPiek, I just tried that but nothing happened.
                  It is just like before, where when I turn on the power button you can hear the machine run for like two or three seconds and then it stops.
                  Still not displaying anything.
                  • JPiek
                    • Oct 2014
                    • 435
                    I think you should do a Boot system error diagnostics, but you would need the manual to go through these steps and find out what is defective...
                    (Start at page 6 - 86, Controller Self Diagnosis > Basic Flowchart)
                    Johan
                    • screwdriver08
                      • Jul 2010
                      • 160
                      Thank You JPiek, do you know where I could get such manual at? Or the name of the manual so I can look for it online.
                      Thank You so much
                      • JPiek
                        • Oct 2014
                        • 435
                        Check PM...
                        Johan
                        • screwdriver08
                          • Jul 2010
                          • 160
                          Does anyone here have the firmware for Canon Imagerunner 2020 that is willing to share with me?
                          • clivealive
                            Manager
                            • Oct 2014
                            • 4
                            I've had a couple of these. In both cases it was the Main Controller 1. Replaced this board, and hey presto, back to life. But you can only fit a new one, and it must be the specific model, as they are locked to speed and set the serial number when powered on.
                            Fig.930 FM4-3139-010 1 MAIN CONTROLLER PCB ASS'Y, 1 C2020 SERIES
                            Fig.930 FM4-3140-010 1 MAIN CONTROLLER PCB ASS'Y, 1 C2025 SERIES
                            Fig.930 FM4-3141-010 1 MAIN CONTROLLER PCB ASS'Y, 1 C2030 SERIES
                            Also had same fault on IrAdv4025, and IrAdvC5051 which was also Main Controller 1 on both counts .... expensive hobby!
                            • screwdriver08
                              • Jul 2010
                              • 160
                              Thank You,
                              Now does anyone know where I can buy such a part for my Machine?
                              I checked the Board and it does have FM-1920 on it, but am not so sure where I can buy such a part.
                              I really need this machine to work, have had it down like this, not working for almost four months now.
