Canon Imagerunner 2020 - Nothing showing up on Control Panel
  • screwdriver08
    replied
    Re: Canon Imagerunner 2020 - Nothing showing up on Control Panel
    It does turn on, but it does not initialize, making sounds that the parts are running and warming up.
    all it does is the light turns on when I turn the power on...that is about it
  • copyman
    replied
    reload system software
  • JPiek
    replied
    Apart from a blank display, does it boot up at all ? Does in initialise ?
    I mean, is it just a blank display or is it dead apart form the powerlight ?
  • Canon Imagerunner 2020 - Nothing showing up on Control Panel
    Copier was working all right. After turning it off and then on the next day there was nothing showing up on the Control Panel, the Copier has power. The Power light on the control panel does turn on when plugged and seems like it is the only one that lights up on the control panel. There is nothing showing at all on the display, so I cant even tell what error it is. I checked the Flat Cable connection from the Control Panel to the Board on the side and seems like it is ok.
    If you have any advice or help please do share.
    Thank You
