Dear All,
I have a 2220i that was working fine. Tried an update via the Canon server which crashed twice so I gave up.
Switched device off, work day over. Came back in the morning, switched device back on, device took 3 minutes to boot up.
Once on the main screen, only the copy option available but will not copy or print.
Re-loaded system software via SST and USB, DC CON will not update.
Flashed the Flash PCB, now device does not boot up at all. Completed all checks via SM, All okay.
Swapped Flash PCB and device boots up fine but then errors. Is Flash PCB unique and can they be purchased ?
Any advice would be greatly received.
