Canon iR Adv C5240 Slow Printing
  • Tim C
    • 167
    I have a problem with a Canon Adv C5240. It is printing very slow when sending a jobs. It copies fine, print quality is good. I have replaced the
    Hard Drive, reset all the connectors and memory. Used my laptop to by pass their Network. Still the same issue. I am taking a fuser I have from a
    C5030 hoping its interchangeable.
    Any Suggestions or fixes would be great !
  • guitar9199
    • Sep 2016
    • 1098
    Re: Canon iR Adv C5240 Slow Printing
    Is it slow on everything, or only PDF's? Also...are you using the UFR II, PCL or PS drivers?
    ...I've found that using PS on a multi-layer PDF can be PAINFULLY slow printing, unless you click the Advanced button the the Adobe print dialogue, and check the "Print as Image" box.
    ....just a thought.
    • roho
      • Mar 2009
      • 844
      I don't believe the fuser is swappable, you will need to change out the film unit which is.
      • Tim C
        • 167
        I have tried both TCP/IP and LPR port, i will check but i believe they are printing word docs, pdf's and emails. all are slow. I will check the
        Print as Image when i am there today
        Originally posted by terramobil
        If copying is fine I don't believe it's a hardware issue (fuser, ITB etc.) I think it's a printer port, driver or application issue. What printer port is used? I prefer TCP/IP or LPR port. WSD port is terribly slow. Which applications are used? As guitar9199 said, if "Prind as Image" is checked, the printfille can be really big when printing PDF files.
        • guitar9199
          • Sep 2016
          • 1098
          If Word documents are printing slowly as well, I would suspect one of two things. Either a print driver problem, or a network related issue.
          If they're using their internet provider as their phone provider as well, it's likely they're running "Power Over Ethernet". Canons don't like P.O.E. at all...and I've had to replace control panel CPU boards because of it. My old company even went as far as creating custom Cat-5 cables with ONLY the data lines connected.
          You might want to ask about that while you're there. It'll save you some "Hair Pulling" frustration.
          "I feel your pain..."
          Steve
          • Tim C
            • 167
            I am trying to send a simple Windows test page and it's taking like 45sec to print. Test P-Print
            is taking 2 min to print from memory
            i am using a laptop with a crossover cable
            still slow. Wondering if it could be a fuser
            issue, I've hear about
            QUOTE=guitar9199;581059]If Word documents are printing slowly as well, I would suspect one of two things. Either a print driver problem, or a network related issue.
            Steve[/QUOTE]
            • JPiek
              • Oct 2014
              • 435
              As said, if copies are at normal speed, rule out the mechanical parts (paperpickup-drum-ITB- fuser). it's either network or jobprocessing related. What if you connect to the webinterface and do direct print from there ?
              Johan
              • Tim C
                • 167
                OK so I tried everything possible to get this machine to print faster.. I gave up and got another C5250 and guess what? The same exact
                issue is with this machine, i did use the hard drive from the old 1st machine which I replaced with a new one pre loaded with software.
                I also updated the firmware .. still doing it..sloooww prints. Seems to be only on the Color jobs.
                • techandtrader
                  • Jun 2016
                  • 318
                  Could a hacked router be causing the trouble? It could be sending flooding attacks. That will cause connectivity lag and trouble.
                  I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                  • SAZ911
                    • Mar 2013
                    • 193
                    Hi Tim,
                    I have just had this issue with duplex printing and just resolved it this morning, I can tell you it will probably be the fixing assy, mine looked perfect but wasn't in the end....
                    Also note 50xx and 52xx fuser are slightly different with the locating screws, 50xx has four screws and the 52xx has 5.
                    please see the link below for more info....
                    Canon IRA C5235i Slow Prints / Copies
                    Good luck....
                    SAZ911..........
                    • niyaskarimba
                      • Sep 2014
                      • 110
                      Dear All,
                      We are facing the same issueof slow printing.Internal prints,counter reports all are working fine.
                      But even when we tried to print directly from laptop its just receiving/processing only.
                      Kindly advice.
                      Thanks in advance.
                      • petermays
                        • Mar 2017
                        • 91
                        hello
                        is mc saying processing a long time before printing?
                        is it spooling on pc along time before getting to mc?
                        is it printing slow..prints coming out is slow?
                        even though you replaced hdd the firmware is also written in main where the prints are been proccessed
                        do a firmware update/over write all
                        or try downgrade firmware.
                          • 22801
                          Originally posted by niyaskarimba
                          Dear All,
                          We are facing the same issue of slow printing.Internal prints,counter reports all are working fine. But even when we tried to print directly from laptop its just receiving/processing only.
                          Kindly advice. Thanks in advance.
                          Sorry to hear that..
                          1) is it the same machine as this thread?
                          2) any supplies near or beyond life?
                          receiving/processing can be network.. controller..even incompatible files.
                          how long has this been going on?
                          you really give us little to go on.
                          • techandtrader
                            • Jun 2016
                            • 318
                            Has anyone loaded the latest driver on a laptop? Try that and make sure a Microsoft loaded driver is not being used in the slow printing computer.
