error code :E0003-0002 canon IR 2880i
  • @Sans_Histoire
    • Feb 2018
    • 6
    [Error Code] error code :E0003-0002 canon IR 2880i
    Good evening!
    I am asking for help to solve my E0003-0002 error problem.
    I have a Canon IR 2880i copier that has a code E0003-0002.
    I changed the fixing unit (oven) and the problem still persists!
    Help me solve
  • copier tech
    • 8093
    Re: error code :E0003-0002 canon IR 2880i
    I guess you reset the code in service mode after you replaced the fixing film ass'y?
    There is a known issue with the door switch, the one at the rear above the fuser, the door hinge plastic cracks so it doesn't make the switch contact.
    • @Sans_Histoire
      • Feb 2018
      • 6
      Thank you. Yes I reset the code in service mode after replacing the fixing film but the problem persists. If you have the opportunity to help me with illustrations in pictures, it would do me good. Thank you in advance !
      • copier tech
        • 8093
        one for you tecat !
        • hidius
          • Jun 2015
          • 128
          this error code brings back nightmares lol .. what we found was the rear bottom door was popping out due to a cracked hinge and causing the interlock switch SW3 to disengage without the door open sensor knowing .. there for causing e0003 because there was no power going to the fixing unit.
          • copier tech
            • 8093
            Pretty much exactly what I said!
