Canon ImageRunner Advance C5255 Manually Open Toner Doors
  • doug
    • Dec 2011
    • 198
    Hi guys,
    Please tell me how to put the "manually open toner door" icon on the maintenance screen trough service mode...
    Thanking you in advance.
    Doug
  • guitar9199
    • Sep 2016
    • 1098
    Re: Canon ImageRunner Advance C5255 Manually Open Toner Doors
    Enter Service Mode and navigate to:
    COPIER > OPTION > DSPLY-SW > Level 2 >< T-CRG-SW> Set to "1"
    Power Cycle the imageRUNNER
    Now enter Settings / Registration > Adjustment / Maintenance > Maintenance >< Replace Specified Toner >
    Follow the on-screen instructions and open the main toner cover.
    Select the [Replacement Needed] tab, and select [Replace. not needed] tab.
    Now all the color toners will be displayed.
    Select the color of the toner to open it's cover.
    Now the [Remove Toner Cartridge] tab will be enabled. Select the Remove Toner Cartridge tab.
    The message [The selected toner still can be used. Do you want to replace it] select YES.
    * The Toner Cover will now open and the toner cartridge can be removed. Follow the on-screen instructions to install the cartridge. *
    ***** Do not replace toner cartridges until the message prompting you to do so appears.
    • doug
      • Dec 2011
      • 198
      Thank you guitar9199! I will try this procedure tomorrow!
      Doug
      • copier tech
        • 8095
        Doug
        Or an even easier way, slide a credit card inbetween the doors this pushes the latch they will pop open!
        • doug
          • Dec 2011
          • 198
          Thank You!
          • willschill
            • Feb 2015
            • 5
            YES - Thanks for this - I have a number of IRc5560i's at an account where we need to come on site to replace toner. the procedure with a card in the upper RH corner of the door does pop it open.
            On this model I needed to reboot afterwards to get the toner chip to recognize the new toner - BIG time saver when at a unit and it is down to 10%
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              Why would you replace toner that is at 10%...you are throwing money away. Also there is new firmware because some toners are sent that are chipless because of the chip shortage.
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
