Unable to see IP4 IP6 settings in Administrative Setup Canon C5255 Color
  • chrisban35
    • Jan 2011
    • 197
    Hello fellow techs, I'm primarily a Xerox dealer who occasionally deals with Canons. Sold a client a Canon IRAC5255 and when we go to the Network Setup mode, unable to see the IP4 IP6 settings. They're not even there grayed out. They're completely missing. I do have the service manual, but I'm having a hard time finding the part where I can go into service mode and turn it back on.
    Of course, that means my "assumption" is that somehow it's actually turned off(disabled) through service mode.
    I would be very appreciative if someone could help me get this "enabled" so I can get my client up and running on the network.
    There's no error codes, and I'm positive that the missing options in the administrative mode means it was manually disabled in service mode.
    I have the "Service Guide" and the "Service Manual"... I do not have a "Network Guide" or anything like that. Please let me know if the information I'm looking for is in one of those service references.
    Thanks in advance for any help you may offer. Much appreciated!
  • 20 year tech
    • May 2014
    • 580
    Re: Unable to see IP4 IP6 settings in Administrative Setup Canon C5255 Color
    Is there a fiery hooked up to it ?
    • teckat
      • 16084
      If a Fiery is connected,
      Check below
      For a Fiery connection
      Service Mode > Option > INT-FACE > IMG-CONT = 3 (or 4 if engine is B/W only)
      If no Fiery- IMG-CONT needs to be at "0" for setting up IP addresses
      • teckat
        • 16084
        C5255____eManual link below
        TCP/IPv4 Settings - Canon imageRUNNER ADVANCE C5255/C5250/C5240/C5240A/C5235A e-Manual
        How to change the TCP/IP addresses using the remote user interface (RUI)
        Enter the IP address for the copier in a web browser.
        Enter the System Manager ID.
        Enter the System PIN.
        Click Administration Login.
        Click Settings/Registration.
        Click Network Setting.
        Click IP Address Settings (IPv4) or IP Address Settings (IPv6).
        Enter the new IP Address.
        Enter the Subnet Address, if needed.
        Enter the Gateway Address, if needed.
        Click OK.
        Click Log Out.
        Close the browser.
        Restart the copier.
        • chrisban35
          • Jan 2011
          • 197
          No, there is no Fiery. It must be some other setting. Like security?? Where someone may have disabled the network connections all together.
          Thanks for your answer though. I appreciate those who take the time to respond.
          • 20 year tech
            • May 2014
            • 580
            Check teckats suggestion on going into service mode copier>option>int-face>img-cont and see if it is set to anything other than 0 it is possible there was a fiery on the machine before you got it and no one changed that setting back
            • teckat
              • 16084
              Try this
              Go to Preferences > Confirm Network connection Set changes and Turn On > TCP/IP settings > IPv4 Settings > IP Address Settings and re-enter information. Close the window and re-boot copier
              When selecting the
              Settings / Registration button, all item listed are greyed out and cannot be selected.
              Check to see the setting of
              <AFN-PSWD> in Service Mode.
              This setting is located in Service Mode Level 2 > COPIER > OPTION > USER > AFN-PSWD
              If AFN-PSWD setting is set to "1" LOG In will be required to display items in Settings / Registration.
              The DEFAULT setting for AFN-PSWD is 0, password not required.
              • chrisban35
                • Jan 2011
                • 197
                Thanks to all my fellow techs for helping me here! This community is invaluable because of your efforts! I'm always humbled by the knowledge depth in this group!
                One last question, I cannot remember how to get into Service Mode Level 2. Can you help me with that please?
                Thanks!
                Chris
                • teckat
                  • 16084
                  Entering Service Mode Level 1 and 2 on the imageRUNNER ADVANCE.
                  To go to Service Mode Classic Level 1 follow the steps bellow:
                  1) Select Settings/Registration
                  2) Press 2 & 8 at the same time
                  3) Select Settings/Registration
                  To go to Service Mode level 2, go to Service Mode level 1 and then:
                  1) Select Settings/Registration.
                  2) Select 2.
                  Go to Service Mode follow the steps bellow:
                  4) Select Mode List
                  5) Select Copier
                  6) Select Option
                  7) Select FNC-SW
                  8) Highlight [Level 1] to toggle between level 1 and level 2.
