Canon pixma MG 3620 error 5B02 reset question
  • tonerjockey
    • Apr 2014
    • 553
    Hi guys, happy new year.
    wondering if i have the correct reset for this ? sponge counter (waste sump)
    unplug. hold start, and plug in machine. press resume 4 times.
    thanks for any advice. Jim
  • teckat
    • 16084
    Re: Canon pixma MG 3620 error 5B02 reset question
    Step
    First, unplug the power from the printer and all connections (including USB to the PC as well).
    Step
    Next, press and hold the Start button while plugging the power back into the printer.
    Step
    While still holding the Start button, press the Resume button twice (which then allows for Removal of Ink Cartridges(if you are past the limit otherwise leave them in).
    Step
    Now repeat Step 1 and then repeat Step 2 above.
    Step
    Press the Resume button 4 times (note that the light will only blink the first two times of the four times that you press the button)
    Step
    The error should now have cleared so that you can use the printer.
    • tonerjockey
      • Apr 2014
      • 553
      cool, thanks teckat. i hope you have a nice day. thanks for the info. i will try that if they call me back. Jim
      • teckat
        • 16084
        good luck, it can be a toss up--works sometimes>
