Advance 4235 E840-000 code
  • campy
    • May 2012
    • 315
    Anyone have this problem? I replaced the fuser shutter motor and will change the home sensor tomorrow but I am not confident it's the sensor.
  • Andyboachie
    • 185
    Re: Advance 4235 E840-000 code
    Hello,
    You mentioned that you replaced the fuser shutter motor. Was it showing the same code before you replaced it?
    If the home sensor is off, it will show the same error. This is because even though the shutter might be working, the sensor is not sending a signal of home position of the shutter. The fixing film edge shutter and the motor returns the same code when they are off. Don't also forget about the connections to the DC Board.
    • campy
      • May 2012
      • 315
      Originally posted by Andyboachie
      Hello,
      The code was there before I replaced it. The right rail that it mounts to was broken on the rear side just below the mounting screw so I thought that was it. The rail is not in stock with Canon so I had to glue it, but I am going back with a sensor. I also read last night that the fixing film may be torn so I will check that today.
