Service mode Canon imagePROGRAF PRO-2000 for reset maintenance tank chip?
  • Technoman
    • Mar 2019
    • 7
    The container of reset of ink is filled for only 20%, and the plotter already blocked it. The local dealer and the service center is not engaged in plotters. All work stopped. It would be desirable to turn off this function (at least temporarily) (itself I will monitor the level of ink)
    Somebody will be able to help?
  • teckat
    • 16084
    Re: Service mode Canon imagePROGRAF PRO-2000 for reset maintenance tank chip?
    [ATTACH=CONFIG]42130[/ATTACH]
    eBAY
    Maintenance Tank Chip resetter For Canon Pro1000 Pro2000 Pro4000 MC-20 MC- 30 787893580696 | eBay
    $80.00
    • teckat
      • 16084
      Disable Ink Level Detection on Canon iPF Printer - InkOwl
      • Technoman
        • Mar 2019
        • 7
        Disable Ink Level Detection - I thank, already disconnected
        Maintenance Tank Chip resetter - I know about this device, but it would be desirable to turn off tracking programmatically
        Perhaps it becomes through the service program? Where to get it? (would disconnect almost constant clearing of a head at inclusion when in Maintenance Tank nearly 10 ml of expensive ink every time - very not a beautiful solution merge from Canon for more bysty devastation of purses of users)
        • teckat
          • 16084
          Disabling Ink Level Detection on the PRO-520, PRO-540, PRO-540S, PRO-560, PRO-560S, PRO-2000, PRO-4000, PRO-4000S, PRO-6000, PRO-6000S, TX-2000, TX-3000, TX-4000, TX-5300, TX-5400 printers:
          1. The message "The above ink tank may be an ink tank that ran out of genuine Canon ink or a counterfeit Canon ink tank." will appear on your printer's touchscreen upon installing a cartridge that was once marked as "empty".
          2. Move through the screens, performing the actions described in the messages that appear on the touchscreen.
          3. The printer will eventually ask you to disable detection by holding down the Stop button for at least 5 seconds and then releasing it.
          4. Ink level detection will now be disabled on that color. It will be your responsibility to check the cartridges from time to time and refill well before the cartridges truly run empty.
          don't see anything else
          • Technoman
            • Mar 2019
            • 7
            Thank teckat for help
