Which SMB version support by Canon C5200 series.
  • denvertan
    • May 2019
    • 82
    I have a few Canon C5235i, I would like to know how to check the SMB version supported by those machine.
    Can anyone guide me on this ?
    And does it possible to upgrade it to support SMBv2 or above ? and How to do it ?
  • Iradfo01
    • 20
    Re: Which SMB version support by Canon C5200 series.
    Hi,
    Canon
    Request the customer to use either WebDav or FTP instead of SMB v1 for scan to folder functionality
    When this is not possible or acceptable, update the device with special firmware
    54.58 that adds support forSMB v2 and v3.
    see attached pdf
    • denvertan
      • May 2019
      • 82
      Originally posted by Iradfo01
      Hi,
      Canon recommend the following actions for MFD’s that support only SMB v1 such as iRADV C52XX:
      see attached pdf
      Thank you for the guidance.
      But I did not have that version of firmware. Does you are able to share it with me ? Thank you.
      • disamm
        • Oct 2018
        • 59
        This version can only doawnloaded directly on the device, go to the firmware update menu, select special version and type this values:
        Registration ID: 00006721
        Password: 43149128
        • denvertan
          • May 2019
          • 82
          Password: 43149128
          Thank you for your guidance.
          I try to looking for the firmware update menu as mentioned.
          But all I have is this screen or the screen at the copier both have NO Special Firmware for me to input the password.
          Can you please provide further guidance ? Thank you.
          Screenshot below:
          https://imgur.com/ZdlnE3r
          • disamm
            • Oct 2018
            • 59
            System software cannot be installed via the RUI.
            1. Via Settings/Registration --> but only standard version and updates
            2. Via Service mode --> Standard and Special version, also Downgrade possible.
            • denvertan
              • May 2019
              • 82
              Found the firmware updater at service mode.
              But when I input
              Password: 43149128
              it give me error "Failed to retrive information of special firmware Check the registration ID and Password".
              I double check again the paper service bulletin posted is for C5235 my copier is C5235i (with a "i") does it using different firmware from the one without "i" ?
              • disamm
                • Oct 2018
                • 59
                Tested here with my 5235i and it works.
                if you make a communicationstest, you get an error or ok?
                if you get an error, check the logs.
                this id and password is for all 52XX with and without "i"
                • denvertan
                  • May 2019
                  • 82
                  Tested the Commmunication Test. It shows all OK!
                  But when I try the Registration ID and Password for like 10 times. It always show "Registration ID and Password ERROP"
                  I have attached the CDS server hyperlink address. Any help will be much appreciated.
                  Screen captures:
                  Canon C5235i Firmware Update Failed. - Album on Imgur
                  • tech345
                    • Jan 2017
                    • 6
                    did you put zeroes in ID? it must be 00006721 and not 6721
                    it is a common mistake
                    • denvertan
                      • May 2019
                      • 82
                      Yes I did. Tried it wirh leading zeros, withoit zeros all not working.
                      • disamm
                        • Oct 2018
                        • 59
                        which version is now on the device?
                        • jaeson
                          • Oct 2013
                          • 3
                          Hi,
                          Canon
                          see attached pdf
                          hii, thx for sharing smb firmware info, , how about iradv4245?same special firmware password?
                          • disamm
                            • Oct 2018
                            • 59
                            No, for the 42XX you have another password:
                            00006037
                            44648739
                            • jaeson
                              • Oct 2013
                              • 3
                              00006037
                              44648739
                              okok, tqvm, appreciate
