This thing comes with the SmartWorks software. I cannot seem to figure out why 99% of the time the AIO controller shows offline...
There seems to be no rhyme or reason to this:
It needs the scanner and/or program restarted in order for SmartWorks to show online. When if it comes out of hibernate (weak RAM/HDD so I set it up that way--boot up time is a resource hog--takes probably 10 min to fully boot after login) it says online, but when you hit the go button it asks to insert something to scan. So again restarting everything resolves this.
This is flat annoying...
Also I was told by a tech that the machine was acquired from that the scanner has the capability to scan at much higher resolutions than what SmartWorks can handle (1200dpi). Does anyone know how to achieve this? I have a very specific reason for asking such an absurd question.
