Canon TX 3000 wide format error Hardware error EC31-2F09
  • bryant28282000
    • Jul 2012
    • 145
    Does anyone know what EC31-2F09 error is on a Canon Tx 3000
  • GIUBOSS
    • 1382
    Re: Canon TX 3000 wide format error Hardware error EC31-2F09
    Code: EC31 2F09
    Description: Encoder and wiper blade motor error (support number: 4801)
    Causes: the encoder does not detect the windshield wiper moved to the specified position.
    Solution: 1 Check if foreign substances such as paper debris adhere to the BLEEDING UNIT. Without foreign substances Go to 2. With foreign substances Remove foreign substances. 2 Execute [DIAGNOSIS> PURGE CHECK> INITIALIZATION CHECK] to check the operation of the purge unit. Correct operation Restart and check the operation again. Improper operation Replace BLEEDING UNIT.
    • V-P
      • Apr 2011
      • 679
      There is a known issue with a plastic tube which moves the wipers inside the purge unit.
      You need to replace the purge unit
      If the printer is in warranty - you get it for free.
      Cheers,
      • Canuck
        Tech Specialist
        • 1713
        Yes the purge unit has been modded, but I've greased the gears, long worm gear,etc… never had to go back. Everyone eventually does it we find, but greasing seems to take care of it. Canon actually extended warranty to 18 months because of it
