iR C2020 error E074-0000
  • aAandy
    • Apr 2012
    • 367
    hello everyone
    i know this is an ITB disengagement error, i have both the service and parts manuals, but for the life of me i cannot see where SW01 is nor SL01
    machine was printing blanks, then came up with the error, managed to get rid of the error temporarily and did a stop test - image on drum but not ITB
    machine has done only 44k prints and with the top cover off i can see the ITB disengagement coupling rotate, but it stops in a different position every time
    can anyone tell me where the switch and solenoid are?
    thanks in advance
  • teckat
    • 16084
    Re: iR C2020 error E074-0000
    Originally posted by aAandy
    hello everyone
    thanks in advance
    May find Info here
    Canon IRC 2030 E000074-0000
    • aAandy
      • Apr 2012
      • 367
      Originally posted by teckat
      May find Info here
      thanks Teckat! ended up attending blind, removed rear covers, waste toner assy, HVT boards, harness, main drive and fuser drive, behind which was the alienation 'lever-type' solenoid, which was sticking due to the foam pad having turned to goo - covered the gooey foam pad with sticky tape, cleaned the lever and all good
      interesting to note: getting the main drive back in and aligned correctly with ITB drive release (and other parts) was 'fun' - took 1.5 hrs all up
      • teckat
        • 16084
        👍 Work
        • copier tech
          • 8091
          Thank for the info I will make note of this. Those pads Canon use have been failing like this for years shame they are still using the same material.
          • aAandy
            • Apr 2012
            • 367
            believe it or not, the first time i performed this "sticky tape" repair on a lever type solenoid was on a HP LJ III, which as you likely know is a canon engine - the repair lasted 10 years before the elderly man finally got rid of it
            • copier tech
              • 8091
              I remember the C2380 series reg actuator had a tiny pad this would cause a jam first thing in the morning.
              • Canuck
                Tech Specialist
                • 1713
                Yes them drive assemblies are a nightmare to sync...
