IR 6000 Remote UI
  • KadalK
    • Apr 2025
    IR 6000 Remote UI
    Hello Nice People, first sorry for my bad english. Last month i recently buy an IR 6000 copy machine, then i noticed there are features called Remote UI.
    Im very happy when know i can access my device via web browser, but sadly i cant open it. When i access device Ip address via web, it shows "404 Not Found Your requested URL "/_top.htm" was not found.
    FYI, i can use it for print document normally. But it cant access Remote UI.
    I will be glad if someone can give me advice to resolve it.
    Thankyou for your hardworking and time.. Salam From Indonesia
    Here i got some attachment .
  • copier tech
    • 8091
    Re: IR 6000 Remote UI
    Most likely because this is a old model its not supported by your web browser.
    Try chrome browser & you could also update the firmware this may resolve the issue.
    • Brian8506
      • 1658
      I believe there is somewhere in the user mode maybe under network settings where you can turn the RUI on or off
      • George J
        • 107
        Preferences - Management settings - License/other - Remote Operation Settings
        if I'm not mistaken.
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          The first thumbnail shows Remote UI is on so that shouldn't be the issue. As other tech said, try another browser. only enter IP address in address bar. Maybe try setting static address on a laptop and connect directly to Canon (to eliminate the network as cause) and try.
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • Big Flo
            • Jun 2018
            • 15
            Try HTTP as oppose to HTTPS.
            Try port 8000, too.
            So XXX.XXX.XXX.XXX:8000
            • COPIERTEC ASSOCIATES
              • Aug 2011
              • 278
              Try to check your firmware version as well because older versions of firmware may not support Remote UI.
