Need help with solving an error in Canon IR 3245
  • NeverSayNever
    • 6
    Hello everyone! I need help with solving error 315 subcode 561 on Canon IR 3245. I have tried changing monitor board and power supply board but it didn't work. It would be great if anyone help me resolve it.
    Thanks in advance.
  • bobburnsreb
    • Mar 2015
    • 228
    Re: Need help with solving an error in Canon IR 3245
    I had that code and changed the drum and it never came back. Good Luck!
    • NeverSayNever
      • 6
      Thank you for your reply. I'll let you know when I try it.
      • Iradfo01
        • 20
        its an old device, so fault finding from the manual would suggest you Check connection with DDI-S cable(RCON).
        Replace the main controller PCB ,
        for a 3245 would be FM4-1248-000
        • NeverSayNever
          • 6
          Thank you for your help. But unfortunately it didn't solve the error.
          • NeverSayNever
            • 6
            Thanks a lot. It really worked.
