Canon ir 5075 E004-103
  • saintphotostat@gmail.com
    • May 2016
    • 10
    [Error Code] Canon ir 5075 E004-103
    In canon ir 5075 ,E004-103 I H power supply is ok what could be reason other than ih pcb if anyone have the circuit diagram please share thanks
  • Michael
    • 158
    Re: Canon ir 5075 E004-103
    • Code: E004-0103
    • Description: The IH power supply is faulty/the IH control mechanism is faulty. After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR)
      The IH current is faulty. (no current)
    • Remedy: - Check the connector for any fault in connection. - Replace the fixing heater power supply. - Replace the DC controller PCB.
    Service Manual : CANON IR5055 SERIES SERVICE MANUAL Pdf Download | ManualsLib
    My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN“T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
    You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
    • oombees
      • Apr 2016
      • 27
      I had the same issue not to long ago. I replaced the heating element as well as all thermistors and this resolved my issue.
      Regards
      Sent from my SM-G985F using Tapatalk
