Can anyone please tell me how I can reset Canon Image Runner C5051 to Factory Default? When I press any key on the control panel it is asking for a department id and password. I tried the default ID and password '7654321' but it didn't work. My research indicating that I need to go the service mode but I can't press any keys on the control panel without knowing the department id and password. Please help.......
Canon Image Runner C5051 Factory Default Reset
Re: Canon Image Runner C5051 Factory Default Reset
Thanks. Could you please tell me which one is the additional functions key. I tried the Settings/Registration. I can't find any other button called additional functions.Comment
You have tons of videos on youtube.
Printer is locked for a reason. Contact the administrator or it.If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
So to enter service mods is Settings/Registration> 2 then 8> Settings/Registration again.
Once in service mode to clear Dept ID: COPIER>FUNCTION>CLR>PWD CLEAR
Then restart the machine.
I don't think it's ok for service technicians to give instructions online to regular users how to delete a password.
No hard feelingIf it ain't broke, don't fix it
Years a go I've been stuck working of a brand i've never seen before & this site helped me out so after then I always share info to help others.
Thanks a lot copier tech. I tried the key combinations (pressed settings/registrations then 2 and then 8) but no luck. The MFPs doesn’t respond to these key combinations. The 2 and 8 will simply appear in the department Id box. Looks like settings/registrations key is disabled somewhere. Can you please help?
There is a nack to it.Let us eat, drink, and be merry, because tomorrow we may die!
The 2 & 8 press at same timeRegards Mark
https://copierservices.simdif.comComment
Thanks a lot for kind suggestions. I tried all sort of key combinations with settings/ registrations, 2 and 8 but none of it worked. I watched a YouTube video I can see that when they press the settings/ registrations key the display changes to different menu but my case it still ask for department id and pin. When I reboot the mfp it straight away ask for the ID and Pin. Please let me know if you have any other suggestions.Comment
Thanks a lot for kind suggestions. I tried all sort of key combinations with settings/ registrations, 2 and 8 but none of it worked. I watched a YouTube video I can see that when they press the settings/ registrations key the display changes to different menu but my case it still ask for department id and pin. When I reboot the mfp it straight away ask for the ID and Pin. Please let me know if you have any other suggestions.Let us eat, drink, and be merry, because tomorrow we may die!
I pressed the settings/registrations key at the end. I did exactly what you said. As I mentioned before the printer is not responding to these key combinations. Can you please tell me what you can see in the display if you press only the settings/ registrations key? My printer just ask for the department id and pin when I press this key.Comment
I pressed the settings/registrations key at the end. I did exactly what you said. As I mentioned before the printer is not responding to these key combinations. Can you please tell me what you can see in the display if you press only the settings/ registrations key? My printer just ask for the department id and pin when I press this key.Let us eat, drink, and be merry, because tomorrow we may die!
Maybe the "SVMD-ENT" Value is changed ( SV Mode Level 2 option fnc sw) . Try *49* insteadIf sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
