Canon C5840i and C5740 inversions during duplex scanning
  • tonerhead
    • Sep 2009
    • 582
    If they scan landscape duplex using booklet mode it is fine. If they scan portrait in booklet mode, back side is upside down. Tried in office, same thing. Firmware is current. Any thoughts?
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
  • giogi
    Engineer senior
    • Jan 2016
    • 182
    Re: Canon C5840i and C5740 inversions during duplex scanning
    the workaround is to set up the device in this way:
    FUNCTION SETTINGS>COMMON>SCAN SETTINGS>AUTO SET DIFFERENT SIZE ORIGINAL WHEN USING FEEDER
    settings to ON
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      or scan in OCR, doesn't matter which way document is placed
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • tonerhead
        • Sep 2009
        • 582
        settings to ON
        All copier techs are Gods. You are a God among Gods. Thank you, it worked.
