iradvDX 6755I - E280-002 & E732-0023
  • MunsterTech
    • Sep 2014
    • 377
    [Error Code] iradvDX 6755I - E280-002 & E732-0023
    Hi,
    Went to this machine after another tech was on site originally. He had a E280-002 and ordered a reader controller PCB. When he replaced it, he then got the E732-0023. I visited the site today, just a couple of things, all the reader settings ie X & Y , CCD etc were all at 0, so I put all the settings in from the reader service label. Replaced the HDMI Cable from the RCnt to the Main controller pcb2, but still the E732. I swapped the DADF from one machine to another to check ribbon cables etc, but E732 still persists. If i turn the DADF off in service mode, the machine can operate as a printer, so I am thinking that the Main PCB1 is working fine? I updated the firmware, but switching the DADF back on, E732 comes back. I suspect the MCont 2 pcb, but has anyone seen this before?
    regards
  • MunsterTech
    • Sep 2014
    • 377
    Re: iradvDX 6755I - E280-002 & E732-0023
    forgot to add, i disconnected and reconnected off both 1 and 2 controllers and checked the connections between both boards.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 4999
      Usually E280 is a flat scanner cable. But since you also have an E732 I suspect main controller1.
      • MunsterTech
        • Sep 2014
        • 377
        well, the mystery deepens. Returned to site with a Main controller pcb 1 and 2. Replaced pcb2 first as its the i/f for the reader controller. Still same issue. Replaced main controller 1 and still the same. I have the correct voltage of 24v to the reader controller. I spoke to Canon UK and they said they have never come across this error in the whole of Europe on this model! But says its a reader issue. So no idea what would have caused this, its now with the Remedy team, will keep you posted.
        • Benjamin98
          • Mar 2015
          • 89
          @Munstertech did you ever get any resolve on this issue?
          I have the same problem but it's on the previous generation iR Adv 6555i. Seem to think it's an environment issue. Was there about 2 months ago and reseated connectors on DC CONT PCB as well as on DADF and removed all the dust. It then worked after I powered it on.
          The issue is back now, just wondering if you had any joy with Remedy
          Thanks B
          • nicknt82
            • Nov 2011
            • 154
            Thanks B
            E280-002 :Check cable
            E732-0023: Check maincontroller
            As you said, already replaced main controller 1 & 2 , So i think problem are Reader PCB or DADF PCB
            • Benjamin98
              • Mar 2015
              • 89
              Thanks, yeah. I have replaced the Flat cable so will update if it gives any issues
