Canon ir advance 6255 error 302-001 dead scanner lamp
Re: Canon ir advance 6255 error 302-001 dead scanner lamp
Product : imageRUNNER ADVANCE 6275 / 6265 / 6255Color Image Reader-G1 Title : E302-0001 Error Code Error :
Error code E302-0001 is occurring intermittently when copying or scanning to e-mail.
The definition of the E302-0001 is an error in paper front shading. The sub code of 0001, pertains to the Scanner Unit in the Reader (under the platen glass). If the sub code was 0101, it would indicate a problem with the Scanner in the Document Feeder.
Workaround :
Check the scanner mirrors are clean. Check the connections of the flat cable from the Scanner unit to the Reader Controller. The flat cable has often been shown to be the cause of the error. If reseating the cable does not clear the error, the cable and , or the Scanner Unit may need to be replaced.
Flat Cable Unit FM0-0482-000
Scanner Unit, Reader FM1-B001-000
Follow the procedure regarding replacement of the Scanner Unit in the Duplex Color Image Reader-G1 Service Manual. -
Workaround :
and i tried swap my scanner unit to their machine, the lamp is lights on like normal.
maybe flat cable unit was broke?
Another suggestion?thanks for advice btwComment
Error code E302-0001 occurs after boot up of machine.
Error Clear in service mode was tried. The CCD/Scanner unit and ribbon cable for the Reader unit was replaced. RCON Clear in service mode was tried.
The Reader Controller PCB was replaced. Machine was dirty, optics were cleaned, Copy Board glass & Read Glass were cleaned - both sides.
All four DF White Level adjustments in service mode came up OK.
Workaround :
For this case, the White Platen Roller in the Document Feeder for the Reader Unit Read Glass was very dirty. Cleaning the DADF White Platen Roller thoroughly resolved the service issue of error code E302-0001 occurring after boot up of the machine.Comment
Workaround :
nb: the error appears not after boot up, everything fine after boot up, but i said, scanner lamp didnt lights up, and error appears when i tried to make a copyComment
Just try another reader board sometimes it has been the issue
Actually my DADF is broken long time ago, so i unplugged all 3 dadf socket flex cable on reader controller, is it problem?
