Canon Error E027-0300 IRAC5535
  • Kings
    Steve@Kings
    • Nov 2009
    • 79
    Hi Guys.
    I have a ira5535 with the above error. The machine has been running perfectly for the last two years when the customer phoned me and said they cant get the last inch or so of the Cyan toner tube into the machine.
    So they said they gave it a bang and it went in. As soon as they did this it gives the error after about 7 copies. . After stripping the Cyan set on hopper assembly out of the machine I'm finding the assembly is leaking and has leaked toner into the machine. Do you think it is just a case of replacing that hopper or the toner feed drive as well. Was thinking of going back and swapping the cyan with the magenta and seeing if the error code changes to the magenta code.
    Anyone else had this problem?
    Cheers
  • jalaoly
    • Jul 2014
    • 10
    Re: Canon Error E027-0300 IRAC5535
    Hi,
    Have you verify this
    F01538- E027-0x00 et E021-0x00.pdf
    • dekoster
      • Aug 2012
      • 84
      • Canuck
        Tech Specialist
        • 1713
        Wrong toner and forced it in, breaking the flag hanging down?
        • nicknt82
          • Nov 2011
          • 154
          Originally posted by Kings
          Hi Guys.
          Cheers
          The developer unit is not rotating which is caused by the developer unit coupling breaking. The error code will vary according to the color of the affected developer unit. E00027-0300 = Cyan Developing Assembly
