imagepress c700
  • chughtai
    • Sep 2021
    • 25
    [Misc] imagepress c700
    hi everyone,
    i have canon imagePRESS C700 when i make just one print or copy machine going adjusting fixing assembly some one know about for this
    issue can help me how to handle this. fixing look like good condition upper and lower film and gears i check physical good.
    thanks
  • tonerhead
    • Sep 2009
    • 582
    Re: imagepress c700
    Don't work on this model, however I think you see that when you are running a heavier stock of paper or it is coming out of energy save and it needs time to adjust fuser temp. So likely normal.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
    • wcanonw
      • Aug 2014
      • 404
      Re: imagepress c700
      Originally posted by chughtai
      hi everyone,
      thanks
      • khattab.al.masry
        • 212
        Re: imagepress c700
        Does it related to Main control firmware version
        because we search about MIXM-PFP we did not found it
        • bobburnsreb
          • Mar 2015
          • 228
          Re: imagepress c700
          Read about refresh pressure control in the service manual.
          • khaled_abosere3@yahoo.com
            Head technical support
            • Mar 2012
            • 167
            Re: imagepress c700
            We read it just metioned in service manual but not found in machine service mode
            Sent from my CPH2239 using Tapatalk
            • Hishamawada
              • 174
              Re: imagepress c700
              Check the fixing thermistors. And send their photos
              Sent from my M2101K6I using Tapatalk
              • bobburnsreb
                • Mar 2015
                • 228
                Re: imagepress c700
                Copier> function> cleaning FX-CL-FQ Setting of Fixing Belt refresh
                • Afronixs
                  • Oct 2023
                  • 19
                  Re: imagepress c700
                  hi everyone,
                  thanks
                  hi,
                  Try to apply grease to the metal gears. probably its having dry drive
